Throttle Body Leak
Icyu11725
63
Jan 25, 2012
northport, New York
Alright, so i started doing my boost leak test, and found a leak coming from the elbow gasket, and exhaust manifold gasket going to the tb. So i replaced the gaskets and put some rtv. When i put the tb back in there's a leak coming from the actual throttle (the thing on the spring that the wire is connected to). When push on the nut that's holding it together i can hear the pitch of the whistling noise from the air leaking change. But when i try to tighten the nut, its spins but doesn't get tighter. Also the throttle likes to stick a bunch. i put wd-40, and that didnt help. What should i do? Would i need to rebuild it? Or is it more worth it to buy a 1g tb and do a tb swap. My car is a 1996 eclipse gsx.
i bought my car from someone, but it has a 1g engine swap. how would i tell if its a 1g or 2g throttle body just to make sure?
ok thank you so much, one last question, do you know if pepboys or some autostore would sell them? instead of ording them online, even if its a different brand, i jsut dont want crappy factory stuff
I have check all the mainstream auto stores and I havent found them... And most people will say OEM all the way. Factory parts are usually pretty good
The vacuum nipples on a 1g face the intercooler pipe and on a 2g face the intake manifold.
It'd only be worth while to switch to a 1g (if you don't already have one) if you port the intake manifold opening to 60mm.
Rebuild it. Its very easy and the dealership usually has the seals. If not extreme psi does. Be sure to use plumbers grease when assembling.
You find me a dealership that sells shaft seals and I'll send you an e-cookie :)
