vaccum throttle body lines
tips000
277
Feb 22, 2011
kalkaska, Michigan
what do the vaccum lines on the top of the throttle body control? can i just cap them? will i lose anything from it like heater controls or anything?
so after looking that over i can just cap them? its just emmisions? so all 3 can go?
Depending on emission laws for your state will be the deciding factors for what you do. Here in Arkansas we have almost no emission laws, and none required to register a car. So most of the unneccesary emissions bs may be removed.
i live in northern michigan, theres nothing here either. so what can and cant i do, i dont want to hurt the car at all.
Do some research and see what parts of the emissions system can be blocked off without negatively effecting the car. I had a massive amount of vacuum lines ran every where in mine when I bought it. I had to cap them off and then get the haynes manual out and run everything like it was stock.
FYI: Removing any emissions equipment is against FEDERAL law. Just because your state doesn't check for them, doesn't mean it isn't against the law to remove them.
This includes the catalytic converter, EGR, EVAP/purge stuff, o2 sensors, etc.
My fault I should of mentioned that on my first post with the taboo vacuum delete. You really should take into consideration your state laws with emissions. I know for a fact here in Missouri they don't check for emissions but I still leave mine on and still have my cat.
The 1.8L 4G37 came from the factory with the EGR system blocked off so I don't feel bad at all about blocking off the system on my 2.0L 4G63. I've had my EGR system blocked off for 6 years now and have never failed an inspection. I hope I'm not jinxing myself though as my inspection is due this month...
I passed in Arizona recently with an external dump, a catch can, and not a single vacume line (all the lines on my tb are capped off). Egr is also blocked off and my cat it hollowed out, just depends on your inspector because mine was a "car guy" and said he liked the pink as well haha.
There's no difference between properly capping them off and having that setup shown previously. If you want a cleaner look and don't want to spend the money on getting the tb shown above but a 1g nt tb and cap off the two ports on that.
