Using MODIS on a 1g
AllWheelRS
134
3
Oct 17, 2009
Orange County, New York
So I did some searching and found a thread that says MODIS can be used for data logging but I'm wondering if anyone has actually successfully done it. I tried hooking MODIS to my 92 laser the other day at work, and it doesn't seem to list the 2.0 engine as an option when entering the vin. For those farmiliar with MODIS, I went into Domestic/ chrysler, and it accepts the vin for a 92 plymouth car, but then doesn't give me an option for the 2.0 motor. I then went under eagle talon to see if it would be listed there and still nothing. Anyone experience this before?
I have hooked the MODIS to my 93 Talon and it works fine, are you sure that the firmware is up to date on your MODIS at work? :confused:
You should see chrysler imports, havent used it for logging but i did use it to set my tps when i changed it 91awd
Why not try entering an eclipse or a talon vin?
I want to know if this works too. I just paid $1300 for my import update like a month ago. Never thought I would be able to use my modis. . .
Did you use an adapter that cane with your modis or did you have to make one? I'm very curious to see if I can use mine on my talon
    • dsmmario
    • Detail
    • dsmmario
