Urgent Help Needed!!!!!
boostyGST
325
Aug 11, 2004
Flintstone, Maryland
HEY GUYS I NEED MY CAR UP AND RUNNING TON SO PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
this is the deal, today i decided to clean my engine bay, sprayed engine cleaner on all parts except electrical, then started car before rinsing with water, well while i was wiping everything down the towl i was using got caught in the cam gear, so i ran as quick as i could to turn the car off.
Well after i got the cloth out around the cam gear i went to start the car up and it will sputter for a few then quit.
ran a diagnostic and this is what i got
PO340 Camshaft position sensor A
circut (bank one or single sensor)
What does this mean?
I have a 2G. What could that towl have down it just went around the cam gear did not stop the motor, HELP PLEASE!!!!!!!!
:sosad: :sosad: :cry:
If you keep bumping your thread you're gonna get it locked.
That being said, have you ran a compression test? Leakdown test? Boost Leak test? These are necessary tests to give us an idea of what's going on.
as stated earler in the post, i have done a complete compression test, etc, the head is now off the car completely, but I do not see any noticable damage......what should i do!!!
Tyler
