TSi Kid
- 12
- May 31, 2009
Avondale,
Arizona
I have everything do to my car that i can so far without upgrading my maf and injectors, so now i thought i would start to put some money away to do so
as i let this money pile up i thought i would look into some other options on what maf setup i should run
i want to max out my e3, 25lbs maybe creep it up to 28lbs, and i plan to stick to pump gas which is 91 octane out here
my original plan was to go with what my friends have which is a 3in gmaf and a translator but i was wondering my my other options may be and if this would be the best choice
im not going to run 550s and a 2g maf because theres not enough fuel for my goal
. . . It's not about restriction that makes the use of higher flowing injectors pointless. It's the fact that the maf only meters accurately up to a certain volume flow. The evo 8 maf has an inlet about the same in area and somewhat similar screening/straightening of the air. That will meter far more volume flow; and proven in the 50lb/min range, give or take the ambient conditions.
What I should of wrote is that a 1G MAF cannot support the airflow to need/utilize very large injectors...better?
