update hole in block
hondaslayer1
407
Nov 1, 2009
waukegan, Illinois
pulled the head today and its not good there is a missing piston in number 2 cyl. and have snapped rod and chunk out of the crank and broken piston rings and also went through the front of the block and the back about the size of a baseball. will post pics soon as i take the motor out and go through everything.:barf::barf::barf::barf::barf::barf::barf::barf:
i could see the ball size hole in the front was hidden behind the 02 housing.i how ever did not know about the hole in the back.i can see a peice rod chunk with a wrist pin in it through the hole in the back.:ohdamn:
damn... you did it up right... means the piston is in lil chunks in the oil pan
yup its all inside and in little slivers all over the engine bay and block.what sucks is i never even made it 20 feet on that motor. but now i get to build a 6 bolt but now i cant use the 2g pistons on 1g rods setup.really wanted to do that come since i cant get all forged internals. need to find some one close to me that would like to help me put the 6 bolt together.
It sounds to me that you didn't put the circlips in the pistons if they were full float, or they were improperly pressed on.
how do u post a pic i got the motor out of the car just now so would like to post pics.from what i found is that a rod snapped off and the wrist is on the snapped rod looks toasted. i had a shop press my wrist pins.they also polished my crank dont know who is to blame me or the shop that did the parts.what do u guys think.i know that one of the rods may have been put on backword on to the piston. i have heard that they need to face the same way a certain way.i know the pistons all faced the same way.
it had a crappy idel i think it went way way to lean and blew up.wont really know till its all apart.
Not to bust your bubble or anything but A crappy Idle from being lean wont cause what you have done too your engine.
Sounds to me like she was screaming 6500 and let go! :aha:
Well, if he launched it at 6500 I guess it would only go 20 feet or so at those RPMs til it let go.
Only other way it could be is if the motor was really Really abused before he rebuilt it and the gentle break in he was attempting was enough to tear the bugger apart.
Won't be able to tell till we see pictures.
Well, the pics usually have to be 700 pixels wide
Are you asking about posting in your profile, or in the thread?
Photos in your profile, click on my account tab, there should be a drop down menu. Go to my photos and click. It will show your folders. Click on upload photos.
Or if you are trying to post pictures here, you load them else where. Save the URL to the picture. Then come on here and in the reply box, click on the little mountain, (Between the letter and paper and the little speech bubble,) and then delete the http: that's there and post your url, and then OK. Then hit preview to see if they show up. :)
