So I found a hole...in the block...
ziggo0
774
9
Oct 13, 2009
La Porte, Indiana
Good thing I got another block for this rebuild!
Dang.... thats huge... I just replaced my block with a small pinky size hole due to it throwing a rod... good luck on the build... and remember.... lots of pictures.
Not 100% sure how it happened. I bought the car like this. Guy I bought it off of said he was just cruising along and their buddy behind them was covered in metal and oil LOL. The piston farthest from the timing belt was in many pieces...hopefully going to get the motor out tonight/tomorrow. Definitely lot'so'pictures.
im gonna 3rd the jb weld and mighty putty ftw haha i have a small leak in one of my clutch fluid lines through some mighty putty on it and bam fixed her right up LOL im sure it will work in your application too
Well, I got the motor part of the way out...EVERYTHING disconnected, all bolts out of tranny to block...I'm trying to pull it with the transmission staying in the car. However...I'm trying to understand how in the hell people got enough clearance to pull the motor out with the flywheel/clutch attached to the crank? It looks impossible to get enough clearance to pull the motor out! Any hints?
Edit: nevermind, just going to pull it all together as one.
Yeah drop it out the bottom of the car.
