unmarked injectors
hotrodssnova
694
46
Feb 14, 2009
Houston, Texas
I seem to have a set of injectors that are unmarked. I have a maft and related parts mounted in a pull thru set up. The injectors do not have any markings on them at all. I do know they are low imp. And if mem serves right, they have two holes at the busy end. They are what I would call a maroon color. I have searched on here and eBay and Google with no decent results. My high fuel trim is at 112 on mmcd set with the maft at 800 cc injectors. Just wondering if anybody has come across something like this.
pink - 240cc - (1g 2.0Ln/t)
tan - 390cc - (1g turbo auto)
blue - 450cc - (1g turbo m/t, Galant VR4)
black - 450cc - (2g turbo)
yellow - 510cc - (evo 1-3)
pink - 560cc - (evo 7-9)
Being pink they could be 240cc out of a 1g n/t 2.0L, or they could be 560cc ones from an evo 7-9. They should have the size on one of the sides where the connector plugs into the injector.
I have them out of the car and they are defiantly not pink. They are a maroon color for sure. The ohm meter reads 3.0 on all 4. I have cleaned them to a spotless shine, and the only number on the injectors is a # 2 next to where the little opening is. There are no numbers any where else on these things. I am going to get some pics and post them in a bit. Then I'm going to put them back in, one of my 450's just died. I'm tuning with a maft and my logger. I don't have a wideband. Stay tuned.
I have got the aux set to"0", base "6" and idle to"4" and the rest at "0". That corresponds to 650 injectors. trust me when i say there are no identifying numbers. The color is closer to purple in the light. my logger says my high fuel trim is at 100% and my low is at 96%. I'm still messing with the mid range now. knock is minimal....3 to 4 counts every so often....possibly phantom knock is my guess.
Back from the dead. I still have no clue what size these are. In the pic, pink is n/a injector, blue one is marked as a 450, and the one in question is at the bottom, no numbers at all.
Any guesses or info available...I have done at least 100 Google searches and can't find anything!
Sent from my PC36100 using Tapatalk
