Uicp ?
Almost forgot about the dave brode intercooler pipe those are usually really cheap, around $100 new, but you would also have to purchase a 2g throttle body elbow or something of the sort. That would only cost about 25 to 30 used on the classifieds or something.
I'd go with the Dave Brode intercooler pipe($73 shipped is what I payed). You'll have to paint it yourself though if you don't want the bov flange to rust($5 can of spray paint).
yeah i was trying to find a website to go and order a dave brode but i couldnt find one? i want 2.5" probably..and no i dont have a 2g tb elbow is that 2.5 or what. if you know anybody selling one let me know..also should i get the 1g bov flange or the greddy if i'm not quite for sure ### i have a greddy also i know you can use one of them for both but which one is it after you drill holes in the flange?
nightspeed87 said:
do you feel a significant response from bigger uicp and whats the biggest size it could be, because I imagen too big would cause a little lag ?
For most 2.5" is plenty... Keep in mind the lower part of the UICP has to be 2.25" to fit properly with your stock intercooler, but dejontool makes a larger SMIC that works nice with a 2.5" pipe. The bigger it is the less lag there will be :) Oh, and yeah you'll notice a fairly big difference with an upgraded UICP since the stock once goes down to about .5" where it bends into the stock SMIC.
thats good because I have a custom one going in on the engine im building up, but i dont know what size it is. Im swapping over from an n/t and the engine im dropping in is a gst motor. Its already built up and in the car the only thing left to complete the swap is the wiring.
pitbullowner_2 said:
wher can i find a new gasket if i was to get the 2g tb elbow?
If you're ordering from dejontool then it comes with everything included for installation (including the gasket I believe).
nightspeed87 said:
arent there even bigger and more efficient aftermarket dsm throttle body elbows to put besides the 2nd gens?
Yes, check dejontool, their 1G UICP's come with the tb elbow.
i'm gonna go with the dave brode setup which doesnt come with a tb elbow. i just dont know if i have abs or not how do i tell? and where can i get a gasket for the 2g tb elbow?
To check on ABS I would probably just slam on my brakes, but that's probably the wrong way of doing it :p If you do it that way just roll down a gravel road at like 30km/h and slam your brakes :)
As for the gasket, I would just make my own, just go to your local autoparts store and they should have the material you need. I made a gasket for my 1G BOV with just a piece of rubber.
are you saying yes i do have abs? when you look at uicp on dejonpwerhouse and others they ask you if you want one with abs or without
Ahh, after a quick search I found that only 92+ dsm's have ABS, so NO you don't have ABS :)
