- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- [AGP RS65 turbo]
[K&N filter]
[Magnecor 8mm wires]
[APEXi S-AFC]
[Apexi ITC]
[Underdrive Pulley]
[EGT, Boost gauges, INNOVATE wideband]
[Full 2.5 manrel intake piping with TurboSmart BOV]
[Apex short Shifter]
[ACT 2600 clutch]
[32"X12"X4" Mishimoto FMIC]
[3" Intake pipe]
[GM 3" MAFT (blowthrough)]
[3" high flow cat]
[3" catback with ST muffler]
[3" downpipe]
[Denso 660s]
[TurboXS Dual stage MBC (trophy)]
[3G VLAs (lifters)]
[external PS fluid cooler]
[custom air/oil cooler]
[Gasket-matched Evo3 manifold]
[Relocated battery (back)]
[Walboro 255lph pump]
[Aeromotive AFPR]
[Fidanza alum. FW]
[Prothane motor mounts]
[Aqua-mist methanol injection kit]
[Fidanza adj. cam gears]
[HKS 264/272 cam combo]
- Mods-Engine
- Wiseco pistons
Eagle rods
Clevite bearings
ported/polished head
Mitsu 4-layer metal HG
ARP hardware
B/S removed
- Mods-Handling
- KYB AGX in all four corners
Ground Control coilover springs
Dual piston calipers
Brembo rotors
SS brake lines
Axxis pads
Dunlop 901 235x45x17 tires
