Turboing the NT
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
So after a lot of careful reading I've decided im going to turbo my nt. I've came up with a list of parts for the conversion and I just wanted to hear peoples input. I'm not completly rebuilding my engine as it only has 54,000 miles on it I don't see the need. I'm only looking to run low boost for now. Around 10 psi or so. Here's the list please feel free to comment and give me some suggestions:
-Turbo mass and pigtail harness to be wired in
-Turbo to mass pipe
-Turbo
-Exhuast mani
-O2 housing
-downpipe
-upper and lower intercooler pipes
-intercooler
-BOV and hard pipe
-reuse part of the na pipe to convert to the na throttle body (na throttle body is larger)
-various hoses for coolant and boost lines
-Turbo ecu
-Extra pins and wires for wireing in one extra wire off mass and the knock sensor
-Knock sensor (block is allready tapped)
-Boost gage, and pod
-SAFC and MMCd
-Turbo fuel pump
-Wastgate actuator
-boost controller
-Turbo 450 injectors and resistor pack
*thanks to talonlvr for the help with the list
I've been looking at FMIC and sidemounts, what's you guy's preference on a decent 1g FMIC? I'd like to be able to retain my AC if possible. Thanks in advance.
Add a 4G63 to that list of parts and you have a winner!
Just kidding, calm down....
But seriously, if you want to make good power and be reliable, do yourself a favor and rebuild that bottom end. But do not just rebuild it, get pistons and rods, by doing this you will be able to make more power more realiably.
It already has a 4g63 and they are a lot stronger than most people realize. My cousin ran 17 psi on his N/T for over a year, when the balance shaft bearings finally let go. We pulled it apart and there was no piston or piston ring damage at all.
