oldman
DSM Wiseman
- 9,788
- 196
- Jun 21, 2003
Dayton,
New Jersey
That would make it lean, not rich.It will let a large amount of un-metered air into the system and cause you to run pig rich
The engine vent hose popping off of the intake will cause the problems you are describing. It will let a large amount of un-metered air into the system and cause you to run pig rich, as it connects to the intake after the mas.
Well actually depending on the size of the boost leak it can actually do some damage, that is if your doing WOT pulls. Under normal driving you should be fine but if your trying to make full boost & your leaking that pressurized air out, the turbo is working much harder to try & produce the required boost. While this isn't so bad with larger turbo's, the T25 is tiny to start with & can barely keep up with even a small amount of boost increase. Now add ontop of that your now making the turbo work even harder. If this is done regularly you will defently shorten the turbos life, not to mention you may also be causing additional engine knock as the inlet charge is now going to be much hotter.
On a side note, I too would also say this sounds like a boost leak issue.
I took a look at that hose that runs off of the middle left edge of the valve cover...the one that should be hooked up to the intake. Is that the "engine vent hose" that you guys are talking about?? I can't figure out where it is supposed to connect to the intake though. Should I take some pictures from any particular angle?? I have had this hose not connected to the intake at all since I have had the car, although I understand that this doesn't mean it is safe, I just wanted to mention it in case that information is of significance to what is happening right now. Thanks for the help!
Just to elaborate on the boost leak rich/lean thing,
if you have a leak after the turbo,
non boost- lean
on boost- rich
before the turbo, after the maf
non boost- lean
on boost - lean
ISNT THAT CORRECT>?
before this gets locked for being another "wtfxor BLT champions of the world" thread
Hmmm, I remember having to rev to kingdom come to get my small 16g to spool enough in neutral. I'm sure he knows what he's doing. . . Subaru guys usually know alot about mitsus. They're competition. But, I don't know about the revving her up to detect a boost leak. Seams like a waste of gas and I like to save my rpms for good use. Patience is a virtue. But, I may be b!tchy about my car, too.B-lackGSX99 said:T'row afternoon, i'll be swinging the car by a Subaru dealership that my roommate manages. He tells me his service guy says he "knows all there is to know about turbo talons/eclipses". Yeah, I know WTF .Anyways, he wants to throw it up on a hoist, rev it gently yet hard enough to build a little boost, and listen underneath with a stethoscope in order to locate the leak.
Don't waste your time, it won't work.Yes, i'm very curious to see how this guy goes about testing for a boost leak up on a hoist. My car is a 5-speed, so a brake stand is out of the question either way. Can you even get a car into gear without the tires being on the ground?? If so, i'd only need to get it up to around 2400rpm before you begin to hear the odd turbo spooling sound...but you're right, I can't imagine how he's gonna hear anything over the sound of the engine/exhaust (keeping in mind, it's pretty well 3 inch diameter piping front to back...BWAAARRRRRRR, it's loud). I hope he doesn't go deaf, holding the stethoscope up to things, hahahaha.
If any of you are wondering how this is all going to go down, i'll report back when I get back from Subaru and the store where i'm gonna hopefully grab the remainder of the boost leak tester stuff.
Okay, so the guy at subaru had me start off just by popping the hood (car not on hoist) and firing up the engine. With the car at idle, and stethoscope in ears (the bottom disc piece that usually goes on your chest removed so it was just a hose) he commented right off the bat that it sounds like I have an exhaust leak. He then put the hose end up underneath the exhaust manifold cover and said he could definitely hear air coming out. I took the stethoscope and listened in this area and could hear air also. So his recommendation is to get the car into a specialist to remove the turbo and exhaust manifold. Have this specialist send these parts to a machinist to polish down the connecting surfaces, and reseal it all with high temp sealant. He also suggested not driving it in the meantime, for fear of destroying/warping anything due to the high heat that was coming out of the exhaust manifold.
By no means does this mean that i'm not going to listen to you guys though. I'm still gonna build a boost leak tester for use (I was able to locate the remaining parts so that I could build one for a3 inch diameter turbo inlet). It's not a pcv end cap, but it should do...will post up a pic once it's built, see what you guys think.
My question now, is whether or not you guys feel that the Subaru guy is making sense. Comments, or suggestions??
First time you blow out the tester end at 20 psi, you'll understand why I say this
on the end and fit the coupler on and she holds to 35 psi.
