Turbo replacement
souls25
Aug 22, 2002
Temecula, California
I need to replace my 1g blown 14B turbo. Are the Big 16g and EVO III 16g direct bolt ons? Do I need slight mods? Please help.
Since you have a 1G, which came with a mitsu turbo, those will bolt right on. no modifications needed.
[QUOTE='96_Talon_TSi]Since you have a 1G, which came with a mitsu turbo, those will bolt right on. no modifications needed.[/QUOTE]
Correct. Although it is reccomended with the evoIII 16g that the o2 housing and ex. manifold should be purchased as well. I've read that boost creep can occur sometimes.
I say go with the evoIII. The difference between a small and big 16g is so negligible that is not worth it.
Ok then, I'll go ahead and order the EVO16G, many thanks to all of you. Also, do you think i can still drive my car with the blown 14b?
As long as there is no danger of the turbo flying apart for some reason, it is safe to drive. The mass air sensor input will change, and it'll inject around the proper amount of fuel. It'll probably run really rich at high throttle/WOT, but it'll get you around.
pm me if you would be interested in buying the turbo off my jdm i just ordered. I'm putting my 50 trim on it and don't need it.
    • dsmmario
    • Detail
    • dsmmario
    • my98gsx
