Turbo Oil supply line leak
Dawson159
5+ Year Contributor
157
16
Nov 13, 2017
Billings, Montana
My turbo oil supply line is leaking at the top of the turbo I just had my turbo rebuilt and I just put it back together and everything is good except the turbo oil supply line. What tool can I use to tighten it more because it is in literally the worst spot ever and I think it needs to be tightened a little more for it to stop leaking and I really don’t want to have to take the turbo all the way off to tighten it.
Don’t tighten more just go get new (2) crush washers for the feed into the turbo!
Also, you should be able to take the exhaust manifold off and have complete access to that banjo bolt. When I did this I also torqued all the water/oil bolts to spec.
