turbo install question
patsdsm
51
Oct 10, 2004
rochester, Minnesota
i have a talon and i just purchased a evo 16g and i was wondering if like the oil feed lines and vacuum lines will plug right in on the new turbo or if i will have to change any thing there is a 14b on there now new to the dsm world thanks for the help
everything should bolt right up but you might need to replace various gaskets: oil drain on the turbo and at the pan, possibly turbo to manifold gasket, and turbo to 02 if they are bad. Also might need new copper crush washers for the oil/coolant lines. Lastly, you might need new turbo to manifold bolts if you break them.
Do I have to drain the oil/coolant on this install? I've heard both yes and no...
