turbo 420a exhaust smell?
CYIMSOFAST
Mar 6, 2004
Albany, Georgia
I just turboed the RS im now noticing the exhaust smell is stronger than it was while non turboed. I checked for exhaust leaks but everything seems to be sealed up tight. Is this common becuse it's turboed now?
I'm not a 420a man, but did you put that valve under your map sensor to keep it from seeing positive plenum pressure? Low intake pressure will equate to richer fuel mixture. Just a thought. Good Luck
    • Sdcryan1
