tuning
redrockergsx
84
Feb 16, 2010
el mirage, Arizona
I have a garret 50 trim turbo running i dont know how much boost cause trying to figure out how to hook up my external waste gate with my profec b boost controller. It has 720 injectors and tuning with a apexi safc and i have the correction at +20 at idel and that seem to much but run the 272 cams i got pretty well. but it seem like it hit fuel cut at 14 psi of boost and just to 30 thats bad but i not sure if this turbo is going to need alot of fuel or not is you have any information please help cause i cant do the tune till i get my o2 sensor fix and get my wideband it could just be those that are making it so hard to tune.
agreed......ummm i thought you said you didnt know how much boost you was running but then you just said at 14 you hit fuel cut?
re write the whole thing to where its not a bunched up big ball of info thats hard to sypher through pls
And i dont think u should be hitting fuel cut on that 50-trim with 720cc injectors
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
