injection
- 66
- 0
- Jul 23, 2006
port jervis,
New York
Hey guys i'm pretty sure this is a tuning issue from what i've read and searched around for but i'll explain my issue before i ask my actual question. usually this happens in 3rd-5th the most. if i'm driving down the road say i'm going 50mph in 5th gear or so and i downshift to 4th so i can start to take off the car will start bucking once it hits 15psi or so or around 4,000rpm it wont really do it if i'm at a stop and just take off and start racing or something. Also it does it in them three gears if i'm on the gas but not floored. So here are my mods:
Greddy 24R FMIC
Evo III Big 16G Turbo
650FIC Injectors
255 Fuel Pump
DNP Manifold
MachV SS O2 Housing
Apexi 3" SS Downpipe
Apexi 3" World Sport II
Apexi Twin Camber BOV
Apexi Turbo Timer
Apexi SAFC II
B&M Short Shifter
ACT 2600 Clutch
ACT Flywheel
Injen Intake
Stillen Upper Hard Pipe
Coil On Plug
Now is my problem in the safc/ tuning problem? Is there a way i can get a closer tune with the safc so that it won't do that anymore? Does anyone out there have about the same mods as me? If so would you shard your settings with me? I can tell you guys what mine is maybe that will help figure out something too. here are my settings.
Low (All negative)
1= -2
2= -4
3= -6
4= -10
5= -10
5.5= -10
6= -10
7= -10
High (All negative as well)
1= -21
2= -23
3= -24
4= -23
5= -22
5.5= -22
6= -21
7= -18
Thanks guys hope you can help me out.
Greddy 24R FMIC
650FIC Injectors
255 Fuel Pump
DNP Manifold
MachV SS O2 Housing
Apexi Turbo Timer
Apexi SAFC II
B&M Short Shifter
ACT 2600 Clutch
ACT Flywheel
Injen Intake
Coil On Plug
Low (All negative)
1= -2
2= -4
3= -6
4= -10
5= -10
5.5= -10
6= -10
7= -10
1= -21
2= -23
3= -24
4= -23
5= -22
5.5= -22
6= -21
7= -18
go. The body looked pretty clean. I wonder if the logger could have saved her... Let us know.
