ECMlink Tuning advice (log inside)
HooKnBooK
116
Mar 23, 2009
St. Louis, Missouri
Hey everyone. I was wondering if anyone had any tuning advice. I noticed the AFR seems a little off. I plan on upping the boost until my turbo stops producing. Let me know what you think please! Thanks
Is there a reason that it went into open loop mode before you did the pull? Weird. Also, in the first part of the log, I'd play around some more with the VE table and try to get those fuel trims more inline, but that's just me. Your logged boost is higher than BoostEst numbers for the pull, so I think you need to also play with the VE table at the corresponding cells. I believe you would need to increase the VE numbers.
