trying to spin cams
carl5463729
169
3
Jul 21, 2004
Lancaster, New York
i'm replacing my liftes right now, i got half of them in but now i'm trying the spin the cams to get to the rest, it will spin a little in either direction, but then i apply alot of force and it stops spinning. my car for like 30 seconds to pull it into the garage. i was wondering is it the new lifters are hard to press down or what, i don't want to break anything thanks
take out the plugs,and turn your engine at the crank,much easier..
or put your car in 4th gear and push..
I hope you still have the timing belt on. Your not going to have much luck pushing the pistons down using the valves otherwise.
When you install the lash adjusters you are to first fill them with oil and then bleed then down before installing them so that they aren't pumped up. The cam doesn't push them down it pushes the valve down.
Steve
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
