trying to narrow down, car stalling and fuel issue, please help
davetheman81
163
Jun 16, 2010
randolph, Massachusetts
So i have had my car being looked at for a few days now, and the original problem was, car idles crappy, o2 sensor never cycled , the car idles lean 16/17- 1 and car stalls inbetween shifts when you push in the clutch and coming to a light. Also the ecu in retracting 30 percent fuel which i thino ia what is making me lean, we are reading this though an aem eugo wideband, but it is welded in 6 inches after the o2 housing maybe to close. So far we have changed these things.
o2 sensor
Coolant temp sensor
Tstat
plugs
Injectors
Tranny
tcase
Clutch
Presure plate
tob
Things we havent tried are
New ecu
Plug wires
different blow off valve (tial atmospheric bv50 installed now)
Cable that goes 1g maf to 2g maf
Actual build
6 bolt acl race bearings
Arp head studs
272/272 cams
Dsmlink v3 lte
Act street light flywheel
Act 2600 presure plate
act 2600 unsprung street disk
Compatition throw out bearing
Fp green
1350 cc injectors
Walbro 255
a1000 afpr
Tial wastegate
jmf intake manifold "race"
Stock tbody
Vrsf fmic
fp intake pipe, non resirqulated
Ngk 7es at .022 gap
Thanks for the help!
My car did the same thing and it had trouble starting also. Try replacing your fuel filter! the gas they have now realy sucks
Ok that's a good idea, i will defiantly replace that, atleast then i know i have a new fuel pump, fuel filter and injectors, and can rule out that it would be a filter
i dont see you saying what kind of maf you have or if your on SD...venting to the atmosphere without SD or a properly setup GM maf for atmospheric will cause the stalls between shifts.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
