giovanniv
- 384
- 0
- Aug 8, 2008
normal,
Illinois
Ok so I have looked at vfaq and on postreetonline and have wired them up both ways and none of those ways work!!!! Currently I have it wired like on prostreetonline but I have a question. When it wants me to tap the brown cable with the red stripe (pinout 84) with the gray throttle cable from the safc I don't get what it is saying because pinout 84 on my harness is blue with a white stripe? The brown cable with the red stripe is pinout 90 for me and I use that in the next step for the pink and orange wires. What am I doing wrong with that? Also I was thinking, if I have my red power wire connected and my ground wires should my safc turn on atleast cause it's not. The only thing that happens when I turn on my car is it has a rough idle.....
. Well I guess I know for next time but what do you have to do to wire the knock sensor? I know it was saying that I have to run the purple wire to the ecu but for some reason it doesn't sound that easy....
