trouble with safc
grobsgsx
Apr 30, 2004
eugene, Oregon
I just installed my safc-II and now the car is ideling at like 1300, and is throwing a check engine code, also at idle my af is at full rich. I tried tuning the fuel down at low rpm settings and you can cut the fuel all the way down to 50% and nothing happens.
are you sure it's wired up right?
It must not be wired up or set up properly. If it were and you had the corrections zeroed out, then it should run the same as it did before you installed it
first and foremost.. DO NOT adjust your fuel if you have no idea that 50% is NOT GOOD. WTF
2nd, you have to have messed up the wiring.. just take some time and go through your wiring diagrams and make sure you have it right.
p.s., black and brown should be at LEAST 1/2" apart from each other... and make sure you split the right wire...
