Trouble removing bearings
Ragincajun
34
Dec 14, 2007
Waxahachie, Texas
Cannot remove front bearings. Removed steering nuckle and could not get bearing out. Got the hub to come out and bearing split in half. Any help...:mad::mad:
if you've got an air hammer an some torches, you should be able to pull it out
i had the same problem on my95 talon but it was the rear bearing...
be ready to heat it up for at least 15-20min...there hell to come out..
make sure to clean up the hub when putting it back in to the bearing or you will break it
