Tried grinding,polishing block oil passages
g4ebguy90
2,001
Mar 9, 2011
Rockford, Illinois
Well i had this idea of grinding the oil passages for a nice smoother look.... Well... me being a idiot.
I told my teacher what i wanted to do, he gave me i believe a carbide bit.
So i put it on my 90-degree die grinder and went to work....
well, i took some of the little bits that i could and then i really got into it, and started taking a lot off, ### the surface was really bumpy...
Well after i was done i noticed that i kinda of got the bit to close to the oil passage walls and at the top of most of it, theres a 45 degree angle now were the bit hit it and made it wider then the rest of the passge not bu much im talking like a millimeter, but its still wider a bit then stock now, Im just concerned with the gasket sealing it like this now, i dont see why it wouldnt but... idk im just worried
hopefully u guys have a idea what im talking about.
ok i will tomorrow, but by then ill ask my teacher, like i said if u look at the block were the oil pump goes theres 2 big passages, i grinded them. And now the top of the passage is just a hair wider now ### the bit grinded it a little, its not like its huge, just like a MM, idk i will put up a pic ### its hard to explain.
