Tread stone questions
YungTlon
5+ Year Contributor
104
12
Mar 6, 2018
Pueblo, Colorado
Hello , I wanted to run a tread stone cast 4g63 t3 turbo manifold with a on3 performance .63 ar hotside hosuing turbo (about a 50trim) and I was wondering if anyone’s ran this manifold and had clearance issues . With water pipe , block, etc. any help would be perfect thanks!
Just get the Rev9 manifold instead, they're $115 shipped on eBay and it is the identical part.
Shouldn't have clearance issues at all; you'll need a custom-fabricated o2 housing, however. The 50-trim T04E turbos love being used in their OEM turbine housings...this one was logging right at 40 lb/min at 20psi on pump gas through the stock 2G MAS with 0 knock when it left- car has fuel system mods and a FMIC, everything inside the engine including the cams is 100% stock.
People overlook the old T04E turbos but they're still a great way to make power. This guy had probably $450 total spent on his turbo upgrade including the manifold / Chinagate and it's a completely-different powerband than a 16G in the same price range. Way more top end pull, even on the stock cams.
