90TurboPOS
- 41
- 0
- Mar 13, 2004
San Jose,
California
My Clutch stopped disengauging after a hard 2-3 shift.. I hve modified the master cylinder (grinded down little leg things) put in a longer slave cyl rod.. Right now What I have going on is:
Pedal is firm. When I press it down I can see slave cyl rod come out and push the fork. Looking through the inspection hole thing I can see the pressure plate fingers getting squished.. Fork doesnt seam bent. It looks like the fork could possibly move farther to the left. It rests at about 50/50 (middle of the inspection hole) when compressed completely it could still move maybe 1 cm before the fork hits the bell housing.. Is that normal? It seams like everything is working fine except I cant move it in or out of gear.. If I start in first and leave the pedal depressed the car drives off... Looks like I have to pull the tranny? Clutch blew up? I'm afraid a lame clutch spring fell off or something but I want to exhaust all other solutions before I pull it to find out I didnt need to.
So.. How far towards the passanger side should the slave rod be able to push the fork? If its not pushing it far enough I still have a chance...
I would hate to find out it wasnt needed too late. If anyone have any ideas or perhaps thinks that there is not enough hydrollic preassure (even though it drove for months like that and the slave cyl pushes it form the middle to about .5 cm form the bell housing.. and the fork is making the throughout bearing push the pressure plate fingers until they are about parrallel to the flywheel.. should they go father then that
) please let me know..
