transmission shifting early and eratic
91dsmeclipse
181
Mar 22, 2004
Siloam Springs, Arkansas
i have a 91 eclipse gs non-turbo automatic.my problem is my car is shifting eraticaly and shifts into over drive at about 45 mph when i drive normaly(pressing the gas a little bit)
i adjusted the tps to .5ohms still shifts eratic and early does anyone know what might be the cuase of this?thanx
tps(throttle position sensor) may have gone bad... mine would downshift for no reason and would not shift atthe right time
i have 2 of them i still feel no dif but i could possibly try it agiain or get another one.
A little more detail 'bout the situation would help.
the gears are shifting too early like first to second at 10mph second to third at like 20-25 mph and third to forth at like 45 mph. this is when u are barly pressing the gas.
This sounds normal. When I start out from a standstill in 1st gear and am very light on the throttle I can get my car into 4th gear by 20 mph! This is on my '91 turbo a/t. The lighter you are on the throttle the sooner you'll upshift -- if you have the petal floored it should be holding the gear to redline at least in 1st and 2nd gears.
-Greg
REALLY?when i floor my car it only goes up tp 5600 rpms but i have a non-turbo so maybe its differnt
Every automatic I've ever driven has always run up to redline when the accelerator petal is floored.
i could swear to you when i floor my car it only goes up to 5600 exept for 4th gear
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
