[RESOLVED] Speedo and shifting.
DSMSeifer
68
49
Jan 8, 2003
Bartlesville, Oklahoma
I just aquired another 2G this one happens to be an auto.
On the way home the speedo and odometer both quit working entirely. It also does not seem to be downshifting normaly now.
The fluid level is fine. ( checked warmed up and in neutral)
I have gotten it to work under 1 condition. If I go WoT from a stop the speedo will kick in at about 40-45 and work properly. As soon as the speed drops below 40-45 it drops straight to 0. That method does not seem to work from a roll.
It was supposedly rebuilt in the last 2K miles. My thought is maybe a solenoid but would like some more input before I spend the money on a part I might not need.
I finally got it figured out. I had replaced the speed sensor but not the speed gear. The shaft was bent from improper instalation from the place that rebuilt the tranny. That resulted in chewing off parts of the gear teeth.
So if you have a similar problem inspect the gear and shaft carefully. The part new from the dealer was $22 so its cheap from the dealer and not available from autozone or Orilley.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
