Transmission grinding?
FreStylMotoX01
345
May 20, 2004
Chester, Vermont
ok my laser has this grinding issue. everytime i go in to first or second it grind unless i push the shift knob all the way to the left and push it in slowly. Sometimes it even grinds going in to third. Does anyone else have/had this problem i would like to try and fix it over X-mas break. thanks in advance.
-Jon
try replacing ur master and slave cylinder, and get the shifter kit, all new spacers and whatnot and u should be good
well for my car at a local performence shop they would charge me 250 for installation, the bushings are like 80 all together, i did that and my tranny shifted like a dream
InjenTalon96 gave ya some good advice. But id say try replacing ur tranny an diff oil first. That could be the cause of it. Be alot cheaper solution too.
ya i forgot to say that, def throw in some BG syncroshift, or some royal purple, that will complete it
