1G Transmission bolt location
AWD-Tony
6,787
3,746
Sep 11, 2017
Cincinnati, Ohio
I have tried looking but can’t find it.
Found my trans bolts were loose but only found these 3. Torqued them to 40ftlbs. Where are the other(s)? I will torque the tcase while I’m at it. Glad I didn’t drive to the shootout.
Thanks
Tony
I'm not sure what you mean by where are the bolts but there is one that goes backwards to the other bolts through the "ear" of the block under the starter. Those are all the necessary transmission bolts, everything else is a dirt shield or starter bolt.
Thats all of them Tony. That one on the back is sneaky.
Thanks @Vegas smith !!!!
The top two were finger loose and the other two just needed a half a turn. Should I apply a drop of blue thread lock?
And which ones are these?
