Xarzor
Supporting Member
- 151
- 114
- Jul 21, 2020
Denver,
Colorado
So I just put OEM axle seals in the transmission. Installed them with a seal installer and lubed the outer seal with transmission oil and installed the axles. Took it for a five mile drive and leaking terribly. So bad it's running down the bottom of the car.
OK back story. When I bought the car the axle seals were not leaking but I had to change the CV axles because they were slinging grease. I bought O'Reilly brand CV axles and O'Reilly brand axle seals, because I thought might as well change them not knowing when they were done last. I also switched to Redline 75-90 oil. Within a few days of doing this the axle seals started to leak. But It was just a few drops on the floor of the garage after driving to and from work. I thought it might have been the cheap seals so after a few months I ordered OEM axle seals and chaged my oil to Redline MT-90. And after five miles it's practically just pouring out.
What's the problem here? It's just a lip seal and I know I installed it correctly. I've done dozens of these on different applications with no leaks. The only thing I can think of is the diameter of the cheap CV axles are smaller then OEM.
Thoughts?
Thoughts?
