1G Transmission seals
pbwu1f
222
Feb 27, 2009
West Palm Beach, Florida
I need some help, I can't seem to find P/N for these seals
[/URL] Uploaded with ImageShack.us[/IMG]
They are the main output shaft seal that's actually inside the transmission and the TC output shaft seal. I went to Mitsubishi and they can get it but since I have a Talon I wouldn't be able to return if it was wrong. Any help would be great. Thanks
EDIT- I forgot to put this in the original post but when I took apart the transmission the only thing that was bad was 5th gear. Everything else looked good. I don't know what the piece is called but I got pics.
The first pic is 5th gear without the synchro and the second with. I doubt that a chip like that will make the 5th gear not shift smooth, but it might get worse and crack the gear itself. I know that Mitsubishi has the gear for around $160 but I rather not spend that on something this small.
Did some more research and came up with P/N MD050608-oil seal,m/t input shaft and MD707184-oil seal, fr diff case. The drawing that Mitsubishi provided me are not the best unless you have P/N's, so I'm still not sure if I have the right seals.
