miliman13
- 2,420
- 634
- Jan 1, 2011
tampa,
Florida
So it would appear that i am leaking from the mating surfaces !!!
The Tcase and tranny each have their own unique oil color - so Im not confused and no it’s not the in/out-put seals.
Theres a bead on the center housing i suspect it leaks from the surface that doesnt use a gasket!
Based on the exploded view and the comments made in the 2nd video - and the fact that my Tcase looks like it was sealed with sealant, i can conclude the middle housing to rear housing just uses some sort of RTV
Unlike the middle to front which does has a metal gasket.
But I am asking for clarification
So have any of you had any leaks from the housing mating surfaces ?!
I will take mines apart but I wanted to hear from any of you that may have experienced the same ?
I asume i can just remove the rear housing with out any special consideration.
Thanks
Thanks
