Transfer case leak input seal..
OK's best GSX
52
May 14, 2009
Colbert, Oklahoma
My transfer case is leaking fluid right where it meets up with the tranny
I just replaced the trans case input seal and it is still leaking :cry:
Any advice would be amazing.
Did you grease it and push it in to spec with a like sized socket or punch? Is it actually dripping from the transfer case or the bottom of the bell housing (trans input seal)?
I had the same issue and replaced the seal with no issues. Ended up having the rear go out as well and just bought a rebuild from Jack's Transmission for $350. Hope to never mess with it again after I put it on.
It's from the T-case and running onto the bell housing.
I just replaced it and it's like nothing changed at all
