turbosax2
Moderator
- 4,482
- 669
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
I'm trying to install a temperature sender in my 2g AWD manual transmission. I purchased an adapter to replace the drain plug with that has 1/8" NPT threads, but the temperature sender sticks towards the ground further than I'm comfortable with.
Temperature sender:
M18x1.5 to 1/8" NPT drain plug adapter:
Transmission drain location:
The transmission is in the car and assembled, so I will not drill/tap into the case.
My ideas:
-Drill/tap the stock drain plug to countersink the sender farther into the transmission. I'm not sure how much room I have inside the transmission to go, I'll have to measure this next time I'm at the car.
-A 90 degree adapter of some sort, but I haven't found one suitable. The best I've found so far involves using about 18 different adapters...
Any clever ideas to solve the problem?
Temperature sender:
My ideas:
