Temp switch trigger for transmission oil cooler.
theamsoilguy
132
18
Nov 18, 2010
Edmonton, AB, Canada
I can order a switch that will trigger the oil pump to turn on at a certain temp, The range I can pick from is 140F-210F. I will be putting a bung on the side of the case for this switch.
This is for a track car, quiafe LSD install, 1g transmission. Will only see track use.
What temp would I want the pump to start at? It will auto shut off 15 degrees after the start trigger temp. 210 is probably too hot. 140 is obviously too cold.
What temp range is ideal to run the transmission?
Thanks Al
