Trans not mating flush to block...
High PSI
145
17
Oct 21, 2004
USA, Australia
Had to pull my trans out to figure out where I was leaking oil from (oil galley plug next to freeze plug) and why my clutch wasn't disengaging (clutch disc got stuck to Fidanza flywheel because I only moved the car about 10-feet before I found the oil leak, and thus didn't burn off the green anti-corrosion coating on the flywheel).
I'm on my third motor but as I was installing the trans yesterday I realised I've never installed just the trans myself. When I had the clutch done in 2003 I was totally green and paid a mechanic to do it. Every other time I bolted the trans to the motor and dropped it in from above. Installing the trans alone with the car on jack-stands (and without a tranny-jack, because I couldn't get the car high enough to use it) SUCKS! Probably the worst job I've done on any car...
Anyway, as I was buttoning up the flywheel inspection cover I looked up and noticed that the trans wasn't pulled in all the way on the transfer-case side, but was flush on the slave cylinder side...:ohdamn:
Any suggestions on how to straighten this out? There's really nothing on the transfer case side of the block/trans to pull them together.
Currently the wide and rear motor mounts are installed (cross member and front mount not in yet). My plan was to leave everything connected to the mounts, but to loosen the trans bolts and shake the motor and trans around to see if I can get that dowel to slide in.
You are missing the back side M8 mounting bolt that goes from driver side to passenger side.
Ahhhhhhh! Of course. That hole was driving me nuts - I kept thinking that there had to be something on that side of the block, saw that hole, and thought it would make sense that something would pull that in...but on the other side of that hole (trans) you end up way out next to the axle. I totally forgot that one goes in "backwards".:coy: Massive brain-fart and a consequence of assembling something I disassembled three years ago...
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
