Trans Issue?
eclips3_xs
79
Jul 23, 2008
Burbank, Illinois
Got a trans 5- speed FWD Turbo for a 98 eclipse that i installed. I bought it from a fellow he said its modified as in quifa lsd , 2nd and 3rd gears are doubled sancrode.
How do i know if a have a quifa lsd without tearrin:confused:g the trans apart.
Have someone watch on you while you floor the go pedal around some tight turns. One wheel peel = stock, both = lsd. Unless you still have it out of the car of course which is likely the case.
Or lift one front wheel off ground and SLOWLY let clutch out partially for a tiny bit. If LSD car should move. Just be careful not to let clutch out completely as it will move the car if LSD and you don't want to be driving with a jack under 1 wheel. LOL (If not LSD it will only turn the lifted wheel and clutch can be let out completely).
