tranny question
EclipsexGsx
86
Nov 21, 2008
springfield, Massachusetts
Hi I have a question about a part on the tranny that is suppose to come off. The inner cv joint. Isn it suppose to just pry off? It the one on the right side. Thanks
Insert a pry bar between the transaxle case and the drive shaft, and then pry the drive shaft from the transaxle. Use a pry bar to remove the drive shaft from the B.J. assembly, or the T.J. assembly may be damaged. Do not insert the bar too far, or the oil seal may be damaged.
