Tranny issues
Boostified
62
Dec 23, 2011
Vienna, Missouri
So the other night i did two hard pulls. after. i was driving in town, and it sounded like i had a throwout bearing going out really bad. it does it the worse after I accelerate and let off the gas. or push in the clutch. I took the tranny out, and took the throwout bearing off. how can I really tell if this is the problem? it does it even when I was parked in nuetral. I could rev to like 3300 and let off and it would do it. I can tell its from the tranny. But I dont wanna put the new bearing back on and find out I have to pulled the tranny all over again!!!!
Well it could be the tranny did you replace the tob with a oem one or just took it off? did you inspect it?
What did you inspect when you pulled it off could be the transmission.
When I took mine out, I really couldn't tell what was wrong with it. It was not oem. I think the inside diameter might have been a hair big.
I replaced with oem one and no more noise.
The only thing different is when I pushed the clutch in the noise 98% went away.
Make sure to inspect your clutch and related components. :)
PROBLEM FOUND!!!!!! I took the clutch plate and everything off, and there it was!!!! two of my flywheel bolts backed out!!! they were touching the disc right by the springs!!! im just gonna go ahead and get a new flywhel and clutch kit. im also installing the new TOB and a new slave cylinder. Also two new axles, a new front right wheelbearing and a very small FP Red turbo :)
