tranny issues
riguy
Oct 20, 2008
Cranston, Rhode Island
yesterday i was getting onto the highway and down shifted from 5th to 3rd, it felt like the car never came out of 5th and i tried shifting but it stayed in 5th. i pulled over and the car died. i started it back up and it stayed running as long as i kept my foot on the clutch. I'm able to put the car through the gears but regaurdless of what gear i put it in it stays in 5th. i had to get it towed home and when i was rolling off the flat bed it made a sound like somethin was stuck made a noise every time the tire went around once... i dont know if that helps at all but any advice would be appreciated
Sounds like you're stuck in gear,well first thing i would do is check the shift cables to see if they in tact
Yeh broken shift cable or broken shift fork. Try shift it manually by the transmission. Or have someone shift it while you watch the gear selector on transmission.
i had somebody go through the gears manually while i watched and it went into every gear fine, its got a ACT 2600 with the stock flywheel and had trouble dis-engaging so im thinkin somethin might of just went in the tranny
well my car did the same thing one time but it got stuck in third it felt like it went into other gears fine but did not come out of third in my situation my tranny was gone so worse case scenario is your tranny is done
but good luck with that
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
