General torque app for android obd2
timmytownsend88
73
Apr 21, 2011
Gaston county, North Carolina
i have had this for almost a week and very satisfied in all it cost about 25 dollars for the adapter and the app! it monitors everything.
Did you just get a ebay bluetooth obd2 adapter?
How about a link to the adapter you got?
Measure BHP, Torque & 0-60
Clear car OBD faults
View engine data in Google Earth
See what your car is doing in realtime, get OBD fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU
Layout your own dashboard with the widgets / gauges you want!
It can use the GPS to provide tracker logs with OBD engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / CEL / fault code like a scantool. Helps you fix your car and helps keep repair costs down!
Torque also features:
* Dyno / Dynomometer and Horsepower/HP & Torque
* Can read Transmission Temperatures (vehicle dependant)
* 0-60 speed timings - more accurate than just using plain old GPS - see how fast your car is (or truck )
* CO2 emissions readout
* Customisable dashboard & profiles
* Video your journey using the Track Recorder plugin with onscreen OBDII data overlay - a black box for your car/truck!
* Automatically send GPS tagged tweets directly to twitter (for example if you are going on a road trip)
* Massive fault code database for lookup of fault codes from different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffice reader
* Heads up display / HUD mode for night time driving
* Compass (GPS Based) that won't suffer magnetic interference
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP and MAF sensors (VW & Golf / Audi / Seat etc supported)
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* Car dock support
* Graph data
* Able to share screenshots to Facebook, Twitter, Google+, Email, etc
* AIDL API for third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
oh yeah it does everything more than my dads $200 obd2 reader, you can even see you intake manifold degrees, o2 sensor volts, timing advance you name it its there
I know this thread is almost a year old, but my question is, what can the Torque app specifically do on DSMs? As we all know that not all of the apps features are available for the DSM. Can someone list what it can do on our cars? Couldn't find that info in my searches.
Also, does anyone know of an app that works for 1g OBD I cars?
I found this.
Bluetooth Obd1 adapter for logger | Galant VR-4 > General VR4 Discussions | GalantVR-4.org Mitsubishi Galant VR4 Forum
and this
http://www.matthewsvolvosite.com/forums/viewtopic.php?t=50076&p=249110
Torque Pro Specifically lists OBD2 inside of the program. Also, I do not see any OBD1 bluetooth adapters for sale. Other than the custom made piece in the first link. And at $125 it may be hard to justify.
-Kevin
EDIT:
As alluded to earlier, OBDI protocols and hardware connections are proprietary to each vehicle manufacturer, unlike OBDII which is a universal standard as federally mandated. So there isn't an "OBDI app" and there isn't likely to be one as you'd need specific interface hardware and software for every vehicle manufacturer (GM, Ford, Chrysler and each of the foreign mfrs).
The reason an app like Torque can exist is because the same protocol and hardware will work with every US-spec vehicle made from '96 and up."
Quoted from http://androidforums.com/android-applications/356185-obd1-app.html#post5164888
Keep in mind that you can add custom defined pids(if you know what you are doing) and add other Items to be logged :) in addition to the already defined Items.
Has anyone been able to read intake manifold pressure with one of these android apps? I have tried several and all of them say that pid is unsupported.
Wouldn't that mean you essentially have a $25 boost gauge? Among other things?
Awesome to see feedback on this ! I was looking at that app the other day an wondering if it was worth a damn.. Hmmmm.. I might just have to find a bluetooth obd on ebay now.
This is the adapter I use. Works flawlessly. I recommend it.
[ame]http://www.amazon.com/BAFX-Products-Bluetooth-diagnostics-compatible/dp/B005NLQAHS/ref=sr_1_1?ie=UTF8&qid=1358958680&sr=8-1&keywords=bluetooth+obd[/ame]
Will this work on a 1990 Eclipse GSX?
You have the odb1 port. So this one in particular won't work, and I'm not sure if they sell an adapter for it either.
$125?!? Thats a good start on link imo. Iirc, that odb1 ports are manufacturer specific. Post #15 is where the info is at. First link
Btw, does the elm 327 scan tool (usb) have the capability to be used as a logger?
