ECUflash using evoscan for OBD2 codes
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
I'm confused, on the evoscan website it mentions evoscan can be used to pick up the codes yet after that it shows you the volt-meter method, is there a way to use evoscan to log any codes?
This is a 95 M/T eprom ECU if that matters
I see the DTC area in EvoScan, but I can't get it to work. I can log just fine, but when I want to check the DTC's (my check engine light is on), it ends up saying "No Response from ECU". There was an EvoScan update I just did and it still wont work. Any ideas? Does it need to be using a different driver? I don't see why it would.
if it says no response you may have a bad cable, pin or a bad driver file.
I use windows vista 64 bit. I can do everything fine, Its good practice to use the same usb socket every time to avoid issues.
I can log and flash tunes without an issue. If I go to Auto Zone, their reader works fine. Is there another utility that can get codes?
After EvoScan 2.7 It's very temperamental to Read/Clear DTC's... .
I've noticed it you connect the Flash cable you are using and open EvoScan and read them asap it works most the time.
Personally I just use a ELM 327 Bluetooth Scan tool with Torque on my Android if I need Pull or Clear codes plus it will tell you if the Readiness monitors are set and it works for about anything :)
(Mine came with a Bluetooth dongle that allows you to connect to the scan tool via Bluetooth to my PC ^)
