Took power steering pump out and put back in now shudders when i turn left and right.
95EclipseGST
406
Mar 1, 2002
Kansas City, Missouri
I took the power steering out and when i put it back in and filled it.It bubbled up and out of the cap that was put on tightly. All the power steering fluid settled and i filled it to the max line and it doesnt bubble out anymore but it shudders when i turn left and right.The power steering worked fine before.Should i just keep driving it and it will work itself out? I only turned it back and forth about 10 times shuddering each time then shut off the engine.Anyone know why its doing this? Are there still air bubbles in there working itself out or is something damaged? :confused:
WHEN you turn your wheel to the left & right your supposed to have the car off. not running, when you bleed the system.
also plug the wire back in. it may not be crimped tight enough on the nipple.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
