noise in right rear when turning left
zacksgsx
Dec 11, 2006
Glen Mills, Pennsylvania
Hmmm, I just put on new 225x40x18 Nittos all around on Racing Hart rims. It has H&R race springs so it low with lots of camber. Now I have a noise coming from the right rear wheel area everytime I take a left. You hear nothing going straight or turning right, only left. It is very norticeable when taking left hand sweepers. I thought I was rubbing but I can't see any rub marks. What parts of the suspension should I be looking at for rub (control arm?). Could it be the bearings? Thanks for any ideas. TP
Jack up the car and spin that wheel,if it still hums,your wheel bearing is shot.(youll need to spin it fast by hand, or better if you can get it on a lift)
Also,check the Brake dust shield behind the Rotor,maybe it got bent when you put your wheel on.
It is most likely ## wheel bearing.....## car wud make a loud humming noise and as ## increase speer it wud get louder. Other then that I have the same size tires however i have stock suspension.
