too much boost=rod bearings?
SevensOdd
50
Jul 4, 2006
Duluth, Minnesota
Hey i was wondering if too much boost on a pretty much stock system would cause my rod bearings to die?
well i put my tranny back in today, after the car sat since last november. Took it for a drive, fixing vaccum leaks as i went, and started hearing some bad knocks after a while, while i was off the throttle. Lucky for me i was almost home. So i limped back to my garage, took the vavle cover off, and the heads are fine. So im pretty sure it is the rod bearings. The only problem is how? I was without a boost guage and just kind of eyeballed my MBC. My guess was too much boost.
I don't believe I just read this! OMG
me either....
def. need to uh, not do that? :)
but seriously yea, make sure you have the right still installed so you can tell what's going on. I couldn't imagine knowing the only reason i messed up my motor was because i didn't have something as simple as a boost gauge..
