Too good to be true/new owner
Evanmm
Oct 19, 2017
Ionia, New York
Hey everyone new to the forums. So I've been trying to find a gsx for years since I got my first car (3g eclipse...not that great) but being in NY most are pretty worn for wear.
I found one 2 hours from me but it seems too good to be true. He wants 2500$ for it and says all it needs is a tune and the bumper/hood painted. He has most of the receipts from the work done which is about 5k in the engine and 6k scattered throughout the rest of the build. It's got 130k on the body, new paint, overall seems really clean. I've attached the link and I'm just hoping to get some opinions on it before I commit my day to driving out and looking at it. It does run but it runs very rich and isn't really drivable.
https://rochester.craigslist.org/cto/d/96-gsx-5speed-awd-turbo/6349092781.html
For 2500 its not a terrible deal. Just know you'll prolly spend another 1k getting it to a decent place, at least that's what i've always thought when buying used cars as old as these are getting. Tires look good, lots of parts. It has a lot done to it and i'm sure its been beat, but I always consider if I could get my money back if it turns out to be a crap car. Looks like you could turn around and get that back from someone who could fix it up or part it out. I'd say it's worth a look to see it up close at least. Good luck.
I don't understand why you would put the 450s back in and not just give it a baseline tune? I'm assuming the car has ecmlink. Doesn't say in the post though. The two things I always do when I go to look at a car is #1 compression test #2 I bring a spare oil filter with me and Pull the oil filter off the car and replace it with the new one. And open up the one I just pulled off the car and check for any foreign material. If it looks like the oil filter and oil has just been changed go take it for a test drive for a little while wait for it to cool down and pull it off (this won't work in this situation, I forgot he says it's not drivable cuz the tune). Seems like a good deal if everything is legit on the car.
Id ask for the vin first and google it. I went to see a car advertised as a gsx. First thing I did was look for rear diff and axles. None present. A vin search on google is free and will at least say GS, GST, GSX or whatever it is. I think the price is fair considering it needs several things.. I don't trust buying cars with tons of aftermarket issues. Gig headache. Just me.
FYI saying "Just needs a tune" is the same as buying a car that "Just needs a tune up". It's a put off term that really means "the car runs like crap and needs work but I either don't know what work or don't want to tell you"
Stay away
Compression test no doubt and then also find out if he has DSMLink installed.. "Just needs a Tune" can mean everything from oops I blew my motor because I turned it up and didn't tune it properly, to it actually just needing a tune.. The Compression test will let you know if you need to pursue this deal any further.
OP give the guy a call ask a list of questions that are not clarified in the original post on Craigslist. If he's talking out his a*# or sidestepping questions. Write him off. The only real way you're going to figure this out is by making the trek and looking at the car.
It's literally not worth looking at
The evo3 turbo is an eBay turbo
There is a boost gauge installed under the hood
There has been a half ass wire tuck, the fuse box was moved and so was the coil pack, but the coil pack is just sitting on top of the intake and there are wires all over the engine bay in the wrong spot
The blue racing timing belt is worn through to the black from being improperly tensioned
There are bubbles on the passengers side strut tower
The drivers side motor mount has scratches under the paint showing a maroon color under the engine bay paint by the shock tower. It's also missing seam sealer in that same spot and it's been smoothed over with Bondo and paint
The clutch slave reservoir has over spray on the cap
The drivers side fender side skirt is missing
The front bumper isn't painted
The pcv valve isn't hooked up
The breather off of the valve cover isn't hooked up
The eBay Bov is vented
There are 6 missing valve cover bolts
The car is still running a mass air flow sensor
Seriously you guys need to go get your eyes checked. There's a boost gauge under the hood.....
Well, in my defense I only read the description on my phone, didn't see all of these pics, but I think you have broken it down for everybody LOL... OP, after seeing the pics and a boost gauge located under the hood, I would run far away from this Frankenstein project..
It's the classic "just needs a tune". Basically, the engine is probably blown or there are a million things wrong with it. Also, always assume that a "built" engine is not built at all. The thing doesn't even have any nice parts on it.
Any time I see a "just needs a tune" or "easy fix" I like to ask myself 'why wouldn't they just fix it and sell it as a perfectly running car, if it's so simple?' Most of the time, it's because it's anything but simple and they're just trying to off load the thing.
Right. I've literally seen people say:" All you need to do is connect 1 or 2 wires and it's done!"
Theres still more you find wrong the closer you look
The over flow reservoir is stained a mud brown probably from a bad head gasket
The aftermarket eBay fans wiring is zip tied to the coolant over flow hose over the intake. It's not wired to the factory connector, probably a rigged up switch somewhere. It loops around the intake and then goes back up to the fuse box.
All the little crap adds up and it's a big pile of crap. Unless you have a big shovel and some gloves, I don't think you're ready to get elbow deep in that engine bay
Wow, ya the pics say it all. What a piece of crap! Stay away from it!
Another way to check the VIN for accuracy is here from the vfaq page. The 5th digit will tell you which model it is.
He also makes no mention of a 6-bolt swap even though the spark plug wires are wired for a 2ga inverted firing order, and we can clearly see a 1G cas in the engine pictures, which is also from a 1990 model and isn't a great cas compared to other options. Also has a 1G oil dipstick. Has no vac lines on the throttle body suggest an emissions delete which probably explains why he improperly removed the PCV hose, removed the emission lines on the intake pipe going to the charcoal canister. Doesn't even look like there's any sort of wastegate control.
