Ton of oil on top of valve cover!
^ Same here. All at once.
I can't believe we're still discussing this. It's a valve cover with 6 gaskets. Not too complicated. :|
EDIT: Although, I would like a crack at Mack's post. (I think that's the one I want.) If it didn't take up so much time to explain through words rather than a nice video clip.
holy gorilla grip batman! 16lbs on each bolt!....maybe a combined torque value, but 16 lbs?.LOL Sorry can't get over that, I thought max should be 3. Then again who has a torque wrench that goes that low. LOL
Right on, sarcasm was on a bit there. LOL I only have ever used a regular clicker wrench, and the minimum is 5lbs. I think they are rated 5-80ft. lbs. Thing is I found when I bought mine was the smaller in. wrench cost more?...LOL
16 in. lbs. sounds more like it.
I recently went about undergoing the same problem on my DSM, and on mine it was the valve cover was on too tight! I guess i torqued it too much, and it completely destroyed the gaskets after a while. So i had a nasty oil leak and also oil was on top of the valve cover. The gaskets on these pretty much seal themselves, so be carefull when replacing gaskets.
did any of your guys cars poor out white smoke in between shifts while your VC was cracked or do i have a different problem beside just a cracked VC
