How to remove rust on inside of valve cover
IIv SHaDoW vII
369
May 8, 2007
Topeka, Kansas
Recently bought a really nice looking powdercoated valve cover and the previous owner failed to mention that the inside had a good amount of surface rust.. There is rust all over the inside of the cover and I was wondering if cleaning it is possible.
I did some preliminary searches regarding this and found some threads about people using steel wool..
so after 2 trips to autozone, i went back to work.
**compare with prior posted photos**
I used a lot of this stuff, mildest degreaser i could find that foamed(sorry for the unclear photo):
cleaned up okay for only 5 bucks:
got it decently clean. if you're really motivated, invest in a set of small brushes that can really get in there, and I'm sure the harder stuff will bust right out.
NOTE: if anyone is going to do this, make sure you do it in a WELL ventilated area, let it sit for 15-20 mins, rinse off, start lightly scrubbing (i used shop towels since i could not locate my brass brush), rinse again. After its dry, give it a light coat of wd-40 if you wont be installing it for a while such as myself (thanks to knochgoon24 for the wd-40 tip) :thumb:.
total work time: 45 mins including waiting for the degreaser to work.
